I calculate it again. In the beginning, there are 5 lines in the gs.out file, but now ,empty.
but the CV is smaller like below:
"Maps version 3.04
The internal database of structures extends up to 21 atoms/unit cell, see predstr.out
Among structures of known energy, true and predicted ground states agree
No other ground states of 14 atoms/unit cell or less exist.
Crossvalidation score: 0.074697 "
I don’t know why? because in the beginning, maps found 5 ground state. and then , it discarded them ?
I recently corrected a bug in the convex hull code (in mmaps). Please try version 3.20 (beta version of the latest update).
Sorry for the inconvenience!
it seems I have stumbled into this problem, too. Let me post my output:
Maps version 3.20
The internal database of structures extends at least up to 14 atoms/unit cell, see predstr.out
Crossvalidation score: 0.0630114
All gs files are empty for me, too.
predstr.out has 7131 entries and no g, no e but only u.
My chempots.out only states:
chemical potentials stabilizing multiphase equilibria
ground state indices , structure labels : chemical potentials
chemical potentials stabilizing each ground state
ground state index , structure label : chemical potentials
so it seems there is nothing found. I did run 30 structures and I checked that all individual directories contain the file energy with the correct DFT energy, they do. I ran a simple test system containing Cr,Fe in bcc from lat.in.
I do also see that at some point there are gs-files and chempots.out with values but when I include more data the files turn up empty again.
I got the same problem when I use mmaps, too. It’s my maps.log:
Maps version 3.36
The internal database of structures extends at least up to 0 atoms/unit cell, see predstr.out
No other ground states of 0 atoms/unit cell or less exist.
Crossvalidation score: 0.103785
All gs files and predstr.out are empty for me, too.
