I was running a simulation with the following restart command and fix :
restart 1000000 restart.*
fix 31 all npt temp 1500 300 0.1 iso 0.0 0.0 1.0 drag 2
run 10000000
Now the simulation stopped after 9000000 timesteps (because of computational limitations), and I want to use the read_restart command to restart the simulation exactly from there, and at the same temperature, say 354.2 K, and cool down the system to 300 K over the remaining 1000000 timesteps. It’s specified in the command page that I have to use the same fix ID and group ID, but how should I specify the temperatures ? Should I use something like :
fix 31 all npt temp 354.2 300 0.1 iso 0.0 0.0 1.0 drag 2
run 1000000
Thank you for your help !
Paule
run 10000000
cool down the system to 300 K over the remaining 1000000 timesteps. It's
run 1000000
you should be able to use your original fix npt line, but you have to
change your run command into.
run 1000000 upto start 0 stop 1000000
to complete the run. please have a look at
http://lammps.sandia.gov/doc/run.html for details.
