Hi Axel and LAMMPS users,
Thanks so much for the valuable clue long time ago. I just gained a bit of cplus knowledge and went back to this project. Please let me ask more specifically.
During a verlet run within a “pair” function “compute_force()”, I would like to calculate the pressure (i.e. P=sum(fpair*dx)/Voronoi volume per atom), also I would like to call the Voronoi face area each neighbour pair for further use. The belows are what I have done:
=========for Voronoi volume and Question 1 ===========
In the pair calculation, I added the ptr for the Voronoi calculation:
Compute *Voronoi_info;
Char id_voro[]=”voroinfo”;
Int icompute=modify->find_compute(id_voro);
Voronoi_info=modify->compute[icompute];
Then further call it through:
Voronoi_info->compute_peratom();
Double **voro=Voronoi_info->array_atom;
In input file I just add: compute voroinfo all Voronoi/atom
Until here results show it is all good;
Question 1:
Since, as you said, the “compute_***.h” actually happens after a verlet run(normally when output dump needed), also I indeed feel the simulation is slowed down. So in this way, if here I manually call it during a verlet run, will it actually be called twice? If so, it do severely slow down the simulation, may I ask in which file I can skip off the extra calculation of voronoi?
============for Voronoi face area per pair and Question 2======================
In the “compute.h” I added the container:
std::vector<std::vector> v_face_areas;//to store voro face area of each neighbour pair
std::vector<std::vector> v_neighbors;//to store id of neighbours of each target atom
std::vectorid_target;//to store id of each target atom
Then in the compute_voronoi_atom.cpp;
In function loopCells():
id_target.push_back(i);
In function processCell():
v_neighbors.push_back(neigh);
v_face_areas.push_back(narea);
During the pair calculation;
I call the container using the ptr (mentioned in the voro volume part) as below:
#include “compute.h” and I think they are all in namespace LAMMPS_NS
Voronoi_info->v_face_areas
Voronoi_info->v_neighbors
Voronoi_info->id_target
Question 2:
However, segmentation fault happens here, it shows the address not mapped, which means the ptr seems not work. Could you please provide some suggestions on how this Voronoi information (in “compute_voronoi_atom.cpp”, neigh and narea) can be stored and called outside the Voronoi compute? Or is there anything I can improve for the may I am on?
Many thanks
Best Regards,
Mingrui
