I can only guess, because there are multiple pieces of information missing or difficult to decode:
- you should turn off native language support via “export LC_ALL=C” so I don’t have to guess what “Instruction non premise” means. I guess it would be “Illegal Instruction”.
- you need to provide information about the CPU hardware, e.g. from “grep ‘model name’ /proc/cpuinfo | head -1” and “grep flags /proc/cpuinfo | head -1” or “lscpu”
- you should get a stack trace to identify the location of the failure: https://docs.lammps.org/Errors_debug.html#using-the-gdb-debugger-to-get-a-stack-trace
My suspicion is that this crash is caused by the -D Kokkos_ARCH_SKX=yes setting, which enables extended instructions from the Intel Skylake CPU architecture (AVX512), but that your hardware is older and thus not compatible with that. Try changing the CMake settings with: cmake . -DKokkos_ARCH_SKX=no -DKokkos_ARCH_WSM=yes
and recompile.
