I’d like to use reactive force field, which is provided in the reaxff site but not embedded in the lammps package.
would you explain the format of the ffield.reax.* file (.e.g, ffield.reax.cho) used in LAMMPS so that I can convert the file at the reaxff site to the potential file for LAMMPS?
Relevant information is in (where else?) https://lammps.sandia.gov/doc/pair_reaxc.html
LAMMPS supports the same file format as used in Adri van Duin’s software, thus no conversion is required.
