I have written a data file with many particle species since I want to generate polydisperse ensemble of particles interacting via the Morse potential.
Ane example of it is the following:
LAMMPS Description
4 atoms
4 atom types
0 47.13 xlo xhi
0 47.13 ylo yhi
0 47.13 zlo zhi
Masses
1 0.500363
2 0.519426
3 0.477395
4 0.511256
Pair Coeffs # morse
1 8.1 33 0.984983
2 8.1 33 0.997337
3 8.1 33 0.969675
4 8.1 33 0.992079
Atoms
1 1 46.4506 15.1946 24.5231
2 2 9.79043 6.54441 14.5177
3 3 33.7927 31.4994 34.9494
4 4 27.3936 7.11498 38.2475
My input script reads the following:
units lj
atom_style atomic
pair_style morse 1.4
pair_modify shift yes mix arithmetic
read_data begin.lmp
velocity all create 1 87287 loop geom
fix 1 all nvt temp 1. 1. 5.
thermo 1000
timestep 0.01
dump MYDUMP all atom 1000 dump.lammpstrj
dump_modify MYDUMP sort id
run 1000
The issue is that when I get the error "All pair coeffs are not set (…/pair_morse.cpp:214)” when I try to run the script.
No error occurs if instead I provide a file with the PairIJ Coeffs section instead of Pair Coeff. The issue is therefore with the mixing rules.
Oddly enough, if I use write_data with "pair ii” on, the resulting file cannot be read in input by my script, and the error occurs again. I therefore imagine that I am doing something wrong in the implementation of the mixing rules, but the documentation explicitly indicates that when using Pair Coeffs the mixed coefficient "will be generated automatically by the pair style’s mixing rule”.
Thank you in advance
