Read in Angular Momentum in .lj file
Is it possible to specify the angular momentum in the input file? I see there is a section for the Velocities, but nothing is mentioned regarding the angular momentum.
Also,
I see that if I use a restart file that the data regarding any pair_style commands used in the previous input file will be read in. Does that mean that they are applied? i.e. if I read in a restart file, are the previous potentials automatically applied?
I ask because I want to change the potential each time I read in a restart file.
please see the documentation for the "set" command. it can set lots of
different properties including the per-particle angular momentum.
Also,
you have to check out the documentation of the individual pair styles
in question. each has a section explaining whether a pair style does
support a full restart or not. that said, thanks to the magic of c++,
you can switch or overwrite/re-initialize pair styles any time in the
input (with or without restart) by simply issuing a new pair_style
command and the corresponding pair_coeff commands.
file.
yes, that is possible.
