I am trying to attach DLC film on BCC iron structure.
pair_coeff arguments in below input script worked when I tried to create C and Fe in one input script without using read_restart.
However, I am getting error as “incorrect args for pair coefficients” when I use read_restart to bring out DLC structure.
Here’s what I did in the input script,
Prepare DLC structure with restart file (restart.DLCall_end.1310721)
Read restart file and create iron structure below DLC box
Equilibrate
I am using airebo for C-C bond, and eam/fs for Fe-Fe and Fe-C bonds.
I am not sure if I can generate another structure attached to the structure recalled by read_restart, because I couldn’t define atom types on atoms brought by read_restart.
What if I want to use read_restart twice so that I can bring two different structure with different shape/potential in one input and simulate it? Is it possible? For example, I have semispherical body and box to make sliding contact between them, i.e., restart.sphere and restart.box will be read in the input and simulate sliding contact.
— input ------------------------------------------------------------------
initialization
atom_style atomic
read_restart restart.DLCall_end.1310721
#Fe
lattice bcc 2.87
change_box all z final -17.85 17.85 boundary p p f units box
region
region sub block 0.0 17.85 0.0 17.85 -17.85 0 units box
region box block 0 17.85 0 17.85 -17.85 17.85 units box
region DLC block 0 17.85 0 17.85 0 17.85 units box
#iron
mass 1 55.845
create_atoms
create_atoms 1 region sub
group
group box region box
group iron type 1
group sub region sub
group DLC region DLC
pair_style
pair_style hybrid airebo 3.0 eam/fs
pair_coeff
pair_coeff * * eam/fs Fe-C_Hepburn_Ackland.eam.fs Fe C
pair_coeff * * airebo CH.airebo NULL C
