Reax/c and nve temperature keep increasing
I searched all the problem case of the mail list, but there is no situation like my problem. I really need you guys help.
I used the latest lammps version, which is August 7, 2019. I’m trying to test the B13C2 stability at 300K. I first minimize the system, and then give a 10K stage, after that, I use NVE and temp/rescale to increase the temperature from 10K to 300K. Everything here seems ok, but when I use NVE to run 100000 steps (10ps) to test the stability, the problem happened. The total energy fluctuant just 2eV, seems reasonable, but the temperature slowly keeps increasing from 300K to 340K.
I tried to change timestep to 0.01 and run 10ps, the temperature still keeps increasing.
My input file and part of the log file are shown below. Attachment is my total running package.
Any help is really appreciated.
Peng
Heat B13C2 crystal, ReaxFF test
Initialization
units real
processors 2 2 2
atom_style charge
box tilt large
Atom definition
read_data data.B13C2
replicate 5 5 5 bbox
Settings
pair_style reax/c NULL
pair_coeff * * ffield.reax B C
fix 1 all qeq/reax 1 0.0 10.0 1.0e-6 reax/c
thermo 1
thermo_style custom step temp press pe ke etotal vol density epair
dump 99 all custom 1 dump.reax.atom id type mass xs ys zs
timestep 0.1
Minimization
min_style cg
minimize 1.0e-15 1.0e-15 10000 10000
Heating Stage
velocity all create 10.0 12345 rot yes dist gaussian
fix 2 all nve
run 10000
unfix 2
Heat up
fix 3 all nve
fix 4 all temp/rescale 1 10.0 300.0 1.0 1.0
run 10000
unfix 3
unfix 4
fix 5 all nve
run 100000
LAMMPS (7 Aug 2019)
Reading data file …
triclinic box = (0 0 0) to (5.1868 4.73801 4.53553) with tilt (2.11049 2.11049 1.37031)
2 by 2 by 2 MPI processor grid
reading atoms …
15 atoms
read_data CPU = 0.187428 secs
Replicating atoms …
triclinic box = (0 0 0) to (25.934 23.69 22.6776) with tilt (10.5524 10.5524 6.85153)
bounding box image = (0 0 0) to (0 0 0)
bounding box extra memory = 0.00 MB
average # of replicas added to proc = 38.00 out of 125 (30.40 %)
1875 atoms
replicate CPU = 0.000590121 secs
WARNING: Using ‘neigh_modify every 1 delay 0 check yes’ setting during minimization (…/min.cpp:168)
Neighbor list info …
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 12
ghost atom cutoff = 12
binsize = 6, bins = 8 6 4
2 neighbor lists, perpetual/occasional/extra = 2 0 0
(1) pair reax/c, perpetual
attributes: half, newton off, ghost
pair build: half/bin/newtoff/ghost
stencil: half/ghost/bin/3d/newtoff
bin: standard
(2) fix qeq/reax, perpetual, copy from (1)
pair build: copy
stencil: none
bin: none
Setting up cg style minimization …
Unit style : real
Current step : 0
Per MPI rank memory allocation (min/avg/max) = 147.9 | 148 | 148.1 Mbytes
Step Temp Press PotEng KinEng TotEng Volume Density E_pair v_eqeq
0 0 -83658.22 -285267.37 0 -285267.37 13932.629 2.4516693 -285267.37
45 0 -172668.82 -290227.34 0 -290227.34 13932.629 2.4516693 -290227.34
Loop time of 89.6945 on 8 procs for 45 steps with 1875 atoms
99.1% CPU use with 8 MPI tasks x no OpenMP threads
Minimization stats:
Stopping criterion = linesearch alpha is zero
Energy initial, next-to-last, final =
-285267.36735 -290227.34287 -290227.342859
Force two-norm initial, final = 4843.69 12357.2
Force max component initial, final = 143.549 7263.64
Final line search alpha, max atom move = 5.00848e-17 3.63798e-13
Iterations, force evaluations = 45 719
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
data.B13C2 (888 Bytes)
ffield.reax (17.6 KB)
in.B13C2 (1.04 KB)
