Dear lammps users,
I have tried to do a Reactive Molecular Dynamics Simulation using the lammps software. I installed the lammps-daily and lmp_openmpi (lammps-8Jul13) lammps packages and both of them had similar invalid results. I used a simple system in order that compare my results gaining from the lammps with those from the ReaxFF source Fortran code. Unfortunately, the lammps changes chemical composition of my system as blow:
Input simulations composition for both packages :
100 Oxygen molecules (O2)
50 1,3,5-Trinitrobenzene molecules (C6H3O6N3)
Thermodynamics conditions for both simulations been similar:
T = 300K, without any electric or magnetic field, a = 100 angstrom and NVE ensemble.
I used RDX ffield. in.RDX and param.qeq files were attached to this email.
Output from the lammps reax/c:
number of fragments chemical formula
100 H2
46 C3H6O6N3
1 C5H12O12N6
1 C
1 C6H12O12N6
Output from the ReaxFF source Fortran code:
100 O2
50 C6H3O6N3
It’s clear that lammps reax/c didn’t correctly work. On the other hands, lammps reax/c has changed the atoms in the system with each other.
Can you help me what is the problem?
How I can resolve the mistake?
Thanks in advance
in.RDX (658 Bytes)
param.qeq (96 Bytes)
