Regarding C- Si Morse Potential Global/Cutoff
Dear LAMMPS Experts
Regarding:
indentation of Si substrate with diamond indenter, using the Morse potential for C – Si interaction. The parameters are obtained from reference publications as D0 =0.435 eV, α = 4.6487 Å-1 and r0 = 1.9475 Å.
Issue:
Not able to find cutoff or global cutoff in reference
Query:
If not using the optional cutoff, the global cutoff is used which have a significant effect on force output. Can anyone suggest/advice on the global cutoff for C-Si Morse potential
LAMMPS Version: LAMMPS 64-bit 16Mar2018
if you cannot find a cutoff (it probably is listed somewhere, perhaps not quite obvious), you need to make a test to see how much your results depend on the choice of cutoff. a reasonable choice for atomic scale systems would likely be between 10 \AA (somewhat aggressive) and 15\AA (somewhat careful).
any specific reason why you don’t use a Tersoff pair style? that would seem to be more commonly used for these kinds of systems.
Dear Alex
Thanks for the reply,
Will look for the cutoff in references comprehensively, Indeed I am using a cutoff value of 12. Even small change of 1 A in cutoff has reasonable effect on normal force in test run. Thus looking for reference a value.
The reference publications suggested, Tersoff pair style for Si-Si and C-C, but Morse for C-Si. Will consider your suggestions. Thank You.
Mohit
