Dear ALL,
I would like to do protein-water simulation using CHARMM22 force field with CMAP in lammps. I was able to create the lammps data and input files by charmm2lammps.pl script using Charmm36 with CMAP (as given an example file). It was working without any issue. However, I am unable to create lammps data file using CHARMM22+CMAP (downloaded from http://mackerell.umaryland.edu/charmm_ff.shtml) I have tried for both the current and old versions of the FF i.e. taken from toppar_c36_jul18 and toppar_c32b1. I am obtaining following messages:
Using Charmm36
Info: converting bonds
Warning: bond parameter 2 for [SS SS ] was not found
Info: converting angles
Warning: angle parameter 2 for [SS SS SS ] was not found
Info: converting dihedrals
Warning: dihedral parameter 1 for [SS SS SS SS ] was not found
Info: converting impropers
Warning: improper parameter 1 for [SS SS SS SS ] was not found
Info: conversion complete
No carbon atoms exist in the system
No nitrogen atoms exist in the system
CMAP usage impossible
using charmm22
Warning: bond parameter 1 for [ ] was not found
Warning: bond parameter 2 for [ SS ] was not found
Warning: angle parameter 1 for [ ] was not found
Warning: angle parameter 2 for [ SS ] was not found
Warning: dihedral parameter 1 for [ SS ] was not found
The similar way I tested for charmm22 using toppar_c32b1. I am getting similar warning messages.
Could you help me regarding the above issue? Is there any way to create lammps data file using charmm22 FF with CMAP for the protein-water system.
Thank you very much for any help or suggestions you can provide.
With best regards,
Atanu
