I’m using M-P method to calculate thermal conductivity. I would like calculate its corresponding error as well. I would like to ask a question regarding estimating the error of the temperature gradient. Fix ave/spatial command will give an averaged (over time) value of temperature for each bin. The fluctuation of temperature over time in each bin will give a standard deviation. I would like to ask how to output the temperature of each bin for every timestep so that I could calculate its fluctuation/variance? or is there any way or command to calculate the fluctuations of temperatures in each bin?
Thank you for your help.
Christopher
