Hi , i follow all instruction given in that link also .
i downloaded that potential file from there.
now in lammps i used
make lib-kim args="-b -a Glue_Ercolessi_Adams_Al__MO_324507536345_001"
this command and
build lammps with kim package but still it gives me error
pair_style unkown.
step for my installation are
$ tar Jxvf kim-api-v1.9.3.txz
$ cd kim-api-v1.9.3
$ ./configure
$ make
$ sudo make install
then for model
$ kim-api-v1-collections-management install system --sudo Glue_Ercolessi_Adams_Al__MO_324507536345_001
after that
make yes-kim
make serial
i know this is very basic question but i an new in this.
thanks in advance
I’m unsure what the problem with installation is that Mathur is encountering, but I would recommend using EAM_Dynamo_Ercolessi_Adams_Al__MO_123629422045_003 rather than Glue_Ercolessi_Adams_Al__MO_324507536345_001, as the latter tends to segfault quite frequently. They may use slightly different spline interpolations, but it looks like they’ve given almost exactly the same results for the cases where it hasn’t segfaulted.
Your script looks ok. I don't see anything wrong with what you have described. So, I'm not sure where the break-down is happening.
Can you start the whole set up again from scratch and copy all the terminal i/o (the commands you type and their resulting output)? If you could send that information, it would likely be very helpful in diagnosing your issue.
