Regarding Peri style
I have tried LAMMPS example problem for peridynamics.
When I run the script, screen out put has shown Total # number of neighbors
and Ave neigh/atoms.
May I know how its calculate or on which basis its calculate the above.
Also, I was going through pair_style peri (Lammps documents). It is
mentioned in the document that "*These pair styles do not support mixing*" .
Does it mean that peri style can not use with other style (Using pair_style
hybrid command).
I have attached snapshot for the reference.
With Regards,
*Rushikesh Gite*
M.Tech Student
Department of Applied Mechanics
Indian Institute of Technology Madras
Chennai 600036, India.
Ph: +91-96044-53792
Email: [email protected]...
first available neighbor list on rank 0 after the last step.
mentioned in the document that "These pair styles do not support mixing" .
hybrid command).
no. mixing refers to using arithmetic or geometric averages to obtain
e.g epsilon and sigma for atoms of type i with atoms of type j from
the i vs. i and j vs. j interactions.
peridynamics has no per atom type parameters.
using pair style hybrid with peridynamics makes little sense anyway.
