Hi all,
I am carrying out MD simulation of metal cutting at nanoscale with diamond cutting tool. I am using copper(Cu), beryllium(Be), and CuBe alloy (with 2% Be by weight in Cu) as metallic substratesI am carrying out MD simulation of metal cutting at nanoscale with diamond cutting tool. For Cu and Be separately, EAM potentials (Cu_u3.eam and Be_Agrawal.eam.alloy & Be.abop) are available, however for CuBe , the potential file is not available.
Could you suggest me how to use for CuBe.
Thanks and regards
