Hi All,
I am doing 2d simulation of Yukawa particles.
I have made wall of particles by creating a narrow region on edge.
I am also using neigh_modify exclude command for wall particles.
In position plot i see that particles are not uniformly distributed and
giving different magnitude of repulsive force at different places. How
i make uniform distribution of particles in wall ?
I have made wall only for ylo edge and using periodic boundary condition in that direction.
I have confusion that, this boundary condition is right ?
Force field
pair_style yukawa 1.1962e3 0.011
pair_coeff * * 3.2790e-20
#Settings
neighbor 0.001 bin
neigh_modify every 1 delay 0 check yes exclude group wl wl
Hi All,
1. I have made wall of particles by creating a narrow region on edge.
particles will be located where you place them, and unless you made a
mistake when immobilizing them, they'll stay there.
2. I have made wall only for ylo edge and using periodic boundary condition
in that direction.
it is your model, you have to know what it should look like.
Hi Lammps-Users,
I have distributed randomly 100 particles in wall and 10 particles in the simulation
and applied gravity in -y direction. simulation particles feel different magnitude
of repulsive force at different places of wall because of non- uniform distribution
of wall particles. Due to this different magnitude (balance of gravitational and
repulsive force), particles are not giving a line type structure and giving curve type
structure . You can see particle distribution in fig.,that is present in attachment.
How i find uniform distribution of particles in wall which will gives same magnitude
of force at all places.
Script
units si
atom_style atomic
dimension 2
#Atom definition
distribution.eps (19 KB)
Hi Lammps-Users,
simulation
magnitude
distribution
and
curve type
attachment.
magnitude
LAMMPS will give you what you ask for. if you create a system with
particles at random locations it will behave like that. if you don't
want those particles be a different conformation, you have to adjust
your input accordingly.
furthermore, this is not really a LAMMPS problem, but a problem of
your model (or your expectations). thus you should discuss this with
your adviser.
