Thanks Axel for the reply
this is my input script for pull out after equilibration
Initials of the Data file (created by using moltemplate)
1740 atoms
1717 bonds
3328 angles
4620 dihedrals
4 atom types
7 bond types
15 angle types
37 dihedral types
-10.0 27.0 xlo xhi
-10.0 27.0 ylo yhi
-1.7 14.24 zlo zhi
Masses
1 12.011 #CT “Alkane CH3-” 6 partial charge=-0.18
2 12.011 #CT “Alkane -CH2-” 6 partial charge=-0.12
3 1.008 #HC “Alkane H-C” 1 partial charge=0.06
4 12.010700
Pair Coeffs # lj/cut
1 0.066 3.5
2 0.066 3.5
3 0.03 2.5
4 0.07 3.55
Bond Coeffs # harmonic
1 469 1.4
2 268 1.529
3 268 1.529
4 268 1.529
5 268 1.529
6 340 1.09
7 340 1.09
Angle Coeffs # harmonic
1 85 120
2 58.35 112.7
3 58.35 112.7
4 58.35 112.7
5 58.35 112.7
6 58.35 112.7
7 58.35 112.7
8 58.35 112.7
9 58.35 112.7
10 33 107.8
11 33 107.8
12 37.5 110.7
13 37.5 110.7
14 37.5 110.7
15 37.5 110.7
Dihedral Coeffs # opls
1 0 2.65 0 0
2 1.711 -0.5 0.663 0
3 1.711 -0.5 0.663 0
4 1.711 -0.5 0.663 0
5 1.711 -0.5 0.663 0
6 1.711 -0.5 0.663 0
7 1.711 -0.5 0.663 0
8 1.711 -0.5 0.663 0
9 1.711 -0.5 0.663 0
10 1.3 -0.05 0.2 0
11 1.3 -0.05 0.2 0
12 1.3 -0.05 0.2 0
13 1.3 -0.05 0.2 0
14 1.3 -0.05 0.2 0
15 1.3 -0.05 0.2 0
16 1.3 -0.05 0.2 0
17 1.3 -0.05 0.2 0
18 1.3 -0.05 0.2 0
19 1.3 -0.05 0.2 0
20 1.3 -0.05 0.2 0
21 1.3 -0.05 0.2 0
22 1.3 -0.05 0.2 0
23 1.3 -0.05 0.2 0
24 1.3 -0.05 0.2 0
25 1.3 -0.05 0.2 0
26 0 0 0.3 0
27 0 0 0.3 0
28 0 0 0.3 0
29 0 0 0.3 0
30 0 0 0.3 0
31 0 0 0.3 0
32 0 0 0.3 0
33 0 0 0.3 0
34 0 0 0.3 0
35 0 0 0.3 0
36 0 0 0.3 0
37 0 0 0.3 0
########### script ############
echo screen
----------------- Init Section -----------------
include “D:\ch2-ch3-05-10cnt\system.in.init”
----------------- Atom Definition Section -----------------
read_restart “D:\ch2-ch3-05-10cnt\equi4.restart”
----------------- Settings Section -----------------
include “D:\ch2-ch3-05-10cnt\system.in.settings”
group cnt type 4
group pp type 1 2 3
velocity all create 100.0 154578 dist gaussian mom no rot no
neighbor 3.0 bin
neigh_modify one 25000 page 250000
############## Boundary #############################
#change_box all x scale 1.5 y scale 1.5 z scale 2.0 units box
#change_box all z final -3.5 25.5 boundary p p p remap units box
change_box all boundary p p s #remap units box
################ Group ###############################
region lower block INF 2.4 INF INF INF INF units box
region upper block 16 INF INF INF INF INF units box
group upper region upper
group lower region lower
fix him lower setforce 0.0 0.0 0.0
fix hipp upper setforce 0.0 0.0 0.0
################## for fixing whole polymer ###############
#fix 2 pp setforce 0.0 0.0 0.0
#velocity pp set 0 0 0 #units box
#################### compute ################
compute ape all pe/atom
compute comp all reduce sum c_ape
compute pent cnt reduce sum c_ape
compute pepp pp reduce sum c_ape
#compute cntf cnt property/atom fx fy fz
reset_timestep 0
timestep 0.001
thermo 1000
fix fxnvt all nvt temp 100.0 100.0 1.0
fix pull cnt smd cvel 100.0 -0.080 tether NULL NULL -100.0 1.0
thermo_style custom step temp pe density etotal emol press lx ly f_pull[3] lz c_pent c_pepp c_comp
dump dumpeq1 all custom 3000 pull.lammpstrj id mol type x y z ix iy iz
log pull1.txt
run 1000000
unfix fxnvt
undump dumpeq1
unfix pull
write_restart pull1.restart
write_data pull1.data
issue is that when i perform pull-out test
this warning comes :bond/angle/dihedral extent half of periodic box length
and the value of the energies in simulation become very large.
1- Is there any problem in my pullout script?
2- if there is any problem in equilibration of structure then how to control polymer chain (contains 20 monomer) so that they will not move out of simulation box.
