Regarding RDF output
Dear All
I have calculated four system with 10, 20, 40 and 80 gas molecules. I calculated the RDF between the center atom of gas molecules. However, when I plotted RDF profile in a single graph for different number of molecules, I found that there is no intensity variation. Although higher intensity for higher number of molecules system is logical.
Therefore, The output value of the RDF from LAMMPS is normalized? If so, then I could I get the output without normalization?
Thanks in advance for helping.
Best Regard
James
Dear All
​no. it is not logical at all.
the very definition of the g(r) is the ratio between the actual probability
to find a particle at distance r for the given system and an ideal gas with
the same particle density.​
​you cannot. it would not be a g(r).
axel.​
