Regarding Rotation of 2D system
Dear All,
I want to rotate my 2D particle system such as it is placed on a disk which is rotating
with some angular velocity. I have used fix addtorque command but boundary is creating
problem.
I want to know which command i use to tackle this problem ?.
Thanks in advance.
Regards
Dear All,
is rotating with some angular velocity. I have used fix addtorque command but boundary
is creating problem.
what kind of problem? and how?
there is too little information here to give advice.
If by boundary, you mean periodic boundary, then you can't do it.
Periodic boundaries are fundamentally incompatible with rotating
systems, because angular momentum changes discontinuously each time a
particle is shifted by a periodic cell vector.
If you can construct a non-periodic system, then everything should
work just fine.
Aidan
Thanks for help.
One another question is that if i use non-periodic boundary condition then
atoms will loss. How i tackle atoms loss in non-periodic boundary condition.
If by boundary, you mean periodic boundary, then you can’t do it.
work just fine.
Aidan
2015-11-08 14:21 GMT-07:00 Axel Kohlmeyer <[email protected]>:
You could add a cylindrical wall or freeze atoms that leave the central region.
2015-11-13 18:06 GMT-07:00 Sandeep Kumar <[email protected]...>:
