Greetings,
I am having difficulties getting a region to "move". The following code successfully generates a region within my domain:
region myCyl cylinder z 10.0 10.0 11.0 0.0 9.0 side out
fix wall all wall/region myCyl lj93 1.0 1.0 2.5
However, whenever I try to add "move" to the region command, e.g.
region myCyl cylinder z 10.0 10.0 11.0 0.0 9.0 side out move 0.3 NULL NULL
I receive the following error:
LAMMPS (13 May 2014)
WARNING: OMP_NUM_THREADS environment is not set. (../comm_brick.cpp:82)
ERROR: Illegal region command (../region.cpp:319)
Or, if I try to use a variable (as in the online documentation), e.g. with:
variable v_x equal 0.3
region myCyl cylinder z 10.0 10.0 11.0 0.0 9.0 side out move v_x NULL NULL
ERROR: Variable name for region does not exist (../region.cpp:64)
Strangely, if my move arguments are "NULL NULL NULL" the program runs fine. This might be a meaningless artifact though.
FWIW, my starting point was the in.pour example, I would eventually like the cylinder to move sinusoidally with time, and I am running this through the version obtained via ubuntu apt-get.
Can anyone suggest a correct way to implement region movement (move or rotate)? I imagine it is a simple fix, but I have searched and cannot find a solution.
Jeremy
