[Regression] OVITO 3.16.1 fails Vulkan presentation on dual NVIDIA RTX A5000; bundled fallback requires missing libffi.so.6
Summary
OVITO previously launched and displayed interactive viewports normally on my Ubuntu desktop. After upgrading to 3.16.1, an ordinary launch fails with:
Presenting not supported on this window
ERROR: Failed to create render pass descriptor for onscreen render target.
Explicitly selecting an NVIDIA GPU in OVITO’s graphics configuration does not resolve the problem.
The bundled software fallback also fails independently: its Vulkan driver cannot load because it requires libffi.so.6, which is not present on my system.
I eventually obtained a working launch using a custom wrapper combining NVIDIA/Vulkan selection settings and a temporary libffi compatibility alias. I have not isolated which individual settings are necessary. This should not be required to restore functionality that worked before the upgrade.
Environment
  • OVITO: 3.16.1
  • OS: Ubuntu, x86_64; exact Ubuntu release not recorded in this report
  • GPUs: 2 × NVIDIA RTX A5000
  • Proprietary NVIDIA driver: 595.91.07
  • Desktop/remote access: GNOME Remote Desktop, accessed through a Devolutions RDP client
  • OVITO is launched from a terminal inside the Ubuntu desktop, not through SSH X11 forwarding
  • Shell: zsh
  • Vulkan loader version reported in logs: 1.3.275
  • Installed libffi runtime: libffi.so.8, including libffi.so.8.1.4
  • No libffi.so.6 was initially present
  • vulkaninfo is not installed
  • Exact previously working OVITO version not recorded
NVIDIA GPU/driver output:
NVIDIA RTX A5000, 595.91.07
X display providers:
Providers: number : 2
Provider 0: id: 0x217 cap: 0x1, Source Output crtcs: 4 outputs: 8 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x3fb cap: 0x2, Sink Output crtcs: 4 outputs: 8 associated providers: 1 name:NVIDIA-G0
Reproduction: normal launch
  1. Launch OVITO 3.16.1 from the Ubuntu desktop terminal without the workaround below.
  2. Attempt to display the interactive viewports.
  3. Observe the presentation/render-pass failure.
If a shell wrapper named ovito is already installed, bypass it with:
command ovito
Observed output:
ERROR: VkInstanceCreateInfo::pApplicationInfo::apiVersion has value of 0 which is not permitted. If apiVersion is not 0, then it must be greater than or equal to the value of VK_API_VERSION_1_0 [VUID-VkApplicationInfo-apiVersion]
Reproduction: bundled software fallback
Launch:
OVITO_VULKAN_FALLBACK=1 command ovito
With Vulkan-loader diagnostics enabled, the log shows that OVITO selects its bundled fallback manifest and then cannot load its driver:
Found ICD manifest file .../lib/ovito/vulkan-fallback/lvp_icd.json, version 1.0.0
Searching for ICD drivers named ./libvulkan_lvp.so
ERROR: libffi.so.6: cannot open shared object file: No such file or directory
loader_icd_scan: Failed loading library associated with ICD JSON .../lib/ovito/vulkan-fallback/./libvulkan_lvp.so. Ignoring this JSON
vkCreateInstance: Found no drivers!
Failed to create Vulkan instance: -9
Failed to create platform Vulkan instance
RenderThread: Failed to create Vulkan instance.
The release notes describe the Linux package as supplying its runtime dependencies, with only the GUI’s X client libraries required from the target system. This dependency-loading failure appears inconsistent with that stated behavior.
Tests performed
Test Result
Normal launch Presentation/render-pass failure
Explicit NVIDIA selection in OVITO Same failure
Reset OVITO preferences, then select NVIDIA Same failure
Force QT_QPA_PLATFORM=xcb Same failure
Force QT_QPA_PLATFORM=wayland Cannot connect to a Wayland display; plugin itself is present
Force bundled software fallback Driver loading fails on missing libffi.so.6
Explicitly select the already-installed system lavapipe driver Application/viewport works
Temporary libffi alias with bundled software fallback Application/viewport works
Temporary libffi alias alone, without NVIDIA overrides Original presentation failure remains
Temporary libffi alias plus the NVIDIA settings below Application/viewport works
The system-software-driver launch warned that it could not find the saved NVIDIA adapter selection. That was expected because that test exposed only the software driver.
The successful tests do not establish that every setting in the combined workaround is necessary.
Currently working launch workaround
The following combination starts OVITO successfully:
    compat_dir=$(mktemp -d) || exit
    trap 'rm -f "$compat_dir/libffi.so.6"; rmdir "$compat_dir"' EXIT
    ln -s /usr/lib/x86_64-linux-gnu/libffi.so \
        "$compat_dir/libffi.so.6" || exit
    env -u VK_DRIVER_FILES -u VK_ICD_FILENAMES \
        LD_LIBRARY_PATH="$compat_dir${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" \
        OVITO_VULKAN_FALLBACK=0 \
        __NV_PRIME_RENDER_OFFLOAD=1 \
        __VK_LAYER_NV_optimus=NVIDIA_only \
        QT_VK_PHYSICAL_DEVICE_INDEX=0 \
        ovito
This disables OVITO’s bundled software fallback and explicitly requests NVIDIA device selection.
The temporary alias points the requested libffi.so.6 filename at the system’s existing libffi library. It is an unsupported compatibility experiment, not a claim that the different ABI versions are fully interchangeable.
I have not independently verified the selected runtime GPU through a graphics diagnostic utility, and I have not isolated which parts of this combined command are required.
Additional API-version diagnostic
The following message also appeared during successful software-rendering launches:
Please explain or correct this diagnostic. Its wording is contradictory, and its presence during successful launches makes it difficult to determine whether it is actionable.
I am not asserting that this message causes the NVIDIA presentation failure.
Expected behavior
An ordinary launch of the current OVITO release should initialize a working viewport with the installed proprietary NVIDIA driver, without an undocumented shell wrapper.
If a particular GPU cannot present to the current window surface, OVITO should either select a compatible device or provide an actionable explanation. Explicit GPU selection should also distinguish the available adapters sufficiently on a system with two identically named GPUs.
The bundled fallback should load with the dependencies supplied by the package, consistent with the release notes.
Requested resolution
Please investigate:
  1. The default NVIDIA Vulkan presentation failure on this dual-GPU configuration.
  2. Why explicit adapter selection does not resolve it, while the combined workaround does.
  3. The unresolved libffi.so.6 dependency in the bundled software driver.
  4. The contradictory API-version diagnostic.
  5. A supported fix that restores an ordinary launch without the wrapper.
This upgrade turned a previously working scientific application into a graphics-stack debugging exercise. Faster rendering on configurations that work does not compensate for breaking basic operation on an existing installation. A downgrade or permanent CPU-rendering workaround is not an adequate resolution to the native-rendering regression.
Thank you for the detailed report, it made both problems straightforward to track down. There were indeed two separate bugs, and both are fixed in the current OVITO 3.17.0 development build, which you can download from OVITO Development Builds — OVITO.
1. Viewports failing with “Presenting not supported on this window”
Up to version 3.15, OVITO’s viewports used OpenGL, which always renders on the GPU driving your X screen. Since 3.16, OVITO uses Vulkan, and the GPU was chosen at startup without checking whether it can display images in an X11 window at all. On a system with two GPUs where the X screen runs on only one of them, OVITO could pick the other GPU, and the viewports then failed with exactly the error you saw.
Choosing the GPU explicitly didn’t help because OVITO identified adapters by name only. With two identical “NVIDIA RTX A5000” cards, both selections pointed to the same, first device. Your wrapper most likely worked because of the two NVIDIA PRIME variables (__NV_PRIME_RENDER_OFFLOAD=1, __VK_LAYER_NV_optimus), which let the second card display through the first.
The development build changes this:
  • OVITO now checks which GPUs can display to the viewport windows and picks one that can. If the GPU you selected can’t, OVITO falls back to one that can and prints a warning.
  • Identical GPUs are now numbered (“NVIDIA RTX A5000 #1”, “#2”) in the GPU adapter selection, so each one can be chosen. A selection saved by 3.16 keeps working.
  • If no GPU can display to the window, OVITO now shows a clear error message instead of the render-pass error.
2. Bundled software renderer requiring libffi.so.6
You’re right that this contradicted the release notes. The package build skipped libffi on the assumption that every Linux system provides it. That holds for the library, but not for the version number the driver needs: current distributions such as Ubuntu 22.04 and later only ship libffi.so.8. The package now bundles the right version, and we added an automated check for this to our release testing.
3. The “apiVersion has value of 0” message
This message is harmless and unrelated to the display failure. OVITO leaves the requested Vulkan API version at 0, which the Vulkan specification explicitly permits (it is treated as version 1.0). The Vulkan loader on your system nevertheless reports it, using the confusingly worded text of the corresponding validation rule. That’s why it also appears in successful launches.
Could you please test the development build? Please start it normally, without your wrapper script (the libffi link is no longer needed either), and check whether the viewports work. If they don’t, please post the terminal output and the results of these two runs:
__NV_PRIME_RENDER_OFFLOAD=1 ovito
QT_VK_PHYSICAL_DEVICE_INDEX=1 ovito
That would tell us whether either of your two GPUs can display to your desktop session without help from the NVIDIA PRIME mechanism. We couldn’t fully replicate your setup of two identical NVIDIA cards with GNOME Remote Desktop here, so your confirmation would be very valuable before these fixes go into the next release.
