relativistic equation of motion
Dear All users of LAMMPS
I want to simulate the Molecular dynamic with the relativistic equation of motion and compare it with the classical equation of motion.
Can I do it with LAMMPS?
Do you have any suggestions?
Mohammad
do you see it mentioned anywhere in the manual?
Dear Axel Kohlmeyer
Yes, first of all, I searched in the manual but I did not find any page about it. after that, I sent an email to the mail list because I think maybe there are suggestions or tricks about it.
by the way, I want to say you very very thank you because you help me several times.
In my search, I found the following page of the manual not found:
https://lammps.sandia.gov/doc/USER/atc/man_hardy_fields.html
Best regards
Mohammad
Dear Axel Kohlmeyer
if that is the case you should reformulate your question in a way so that people understand, that you are looking to realize something that is not mentioned in the manual.
however, since this requires a completely different formulation of the equations of motions, i would doubt there is a simple hack/workaround. you would have to look into the details of those and how they need to be implemented to figure out whether it is possible at all to recast a classical MD code to handle a different set of EOMs and then see what modifications to the source code would be required.
that URL is outdated. all ATC documentation has been rewritten in ReStucturedText and its URL would be https://lammps.sandia.gov/doc/atc_hardy_fields.html
Thanks, Axel for your notice and suggestion. Next time I will be asking the question more carefully and clearly.
Thank you for the information.
Mohammad
