I am looking to render some animations of my simulation using the Python implementation of Ovito. In my simulation I have two fixed surfaces on the top and the bottom (as shown in the attached image). DXA picks these up as defects and therefore shows a defect mesh over the top. and bottom of the box, obstructing my view of my system. I am wondering how I might remove the defect mesh when I go to render my simulation results.
I am aware that this was asked previously in this thread, however I believe the solution in that case is to the change the settings of the DXA modifier. My question is can I remove the defect mesh after I have computed the pipeline? Can I remove visual elements from my pipeline after it has been computed? Please see my code for an example of what I’m currently trying to do.
from ovito.io import import_file
from ovito.vis import Viewport
# Import the precipitate IDs
prec_pipeline = import_file('000_data/03_pin_dislo/output/precipitate_ID.txt')
# Import the DXA results (Out of a CA file)
dxa_pipeline = import_file('000_data/03_pin_dislo/dxa/dxa_*')
# Load the pipelines to a scene
prec_pipeline.add_to_scene()
dxa_pipeline.add_to_scene()
# Create viewport settings
vp = Viewport()
vp.type = Viewport.Type.Perspective
vp.camera_dir = (0, 0, 0)
vp.zoom_all()
vp.render_image(size=(800,600), filename="figure.png", background=(1,1,1), frame=1000)
The reason why I ask this is because I perform DXA on my dump files on HPC system. I then download the processed DXA files (in CA format) for visualisation and subsequent data analysis.
Any help would be much appreciated!
E
