Respected sir,
I would like to know if there is any way to remove a group of atoms from a diamond matrix so that I can insert a carbon nanotube in it. I am not able to do it. Can anyone help me with this?
Lavanya
Respected sir,
Lavanya
Respected sir,
option 1: define a cylinder region of the dimensions of your nanotube and delete the diamond atoms with the delete_atoms command
option 2: load your nanotube and your diamond system on top of each other. and the use the delete_atoms command with the overlap option and suitable cutoff.
option 3: use an external program (e.g. VMD with scripting, there is an example for merging to data files with overlap removal in the TopoTools homepage).
option 4: be creative and figure out another way.
Thanks, I’ll check it out.
