replace atom type in a region every n step
Hi all,
I am trying to select “C” atom once it enter to a “region bulk” and replace it with “O” atom, this operation to be done every 1000 step.
the closest I get get is using “set” and “group” commands, but it did not work so far, here is a wrong attempt :
run 10000 every 1000 &
“group C type 2” &
“group C region bulk” &
“set group C type 3” &
I could not find relevant information on so far,
Thank you for helping.
Best regards.
El Tayeb Bentria Ph.D.
QEERI, Qatar.
Hi all,
I am trying to select "C" atom once it enter to a "region bulk" and replace it with "O" atom, this operation to be done every 1000 step.
the closest I get get is using "set" and "group" commands, but it did not work so far, here is a wrong attempt :
"group C type 2" &
"group C region bulk" &
"set group C type 3" &
very relevant information, that you seem to be ignoring, is in the
documentation for the group command (check out the parts about using
the group command multiple times and creating a group from the
intersection of two groups).
Dear Pr. Axel,
Thank you for your prompt replay, and yes, I was completely ignoring “intersect” command, it’s working now.
“group C type 2” &
“group boo region bulk” &
“group C_bulk intersect C boo” &
“set group C_bulk type 5” &
Thank you and best regards.
Tayeb.
