I just ran into this issue too, good to see it’s being taken care of. For reference, here’s the error I was getting before updating my client:
MPRestError Traceback (most recent call last)
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/core/client.py:841, in BaseRester.get_data_by_id(self, document_id, fields)
840 try:
--> 841 results = self._query_resource_data(criteria=criteria, fields=fields, suburl=document_id) # type: ignore
842 except MPRestError:
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/core/client.py:799, in BaseRester._query_resource_data(self, criteria, fields, suburl, use_document_model, timeout)
784 """
785 Query the endpoint for a list of documents without associated meta information. Only
786 returns a single page of results.
796 A list of documents
797 """
--> 799 return self._query_resource( # type: ignore
800 criteria=criteria,
801 fields=fields,
802 suburl=suburl,
803 use_document_model=use_document_model,
804 chunk_size=1000,
805 num_chunks=1,
806 ).get("data")
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/core/client.py:297, in BaseRester._query_resource(self, criteria, fields, suburl, use_document_model, parallel_param, num_chunks, chunk_size, timeout)
295 url += "/"
--> 297 data = self._submit_requests(
298 url=url,
299 criteria=criteria,
300 use_document_model=use_document_model,
301 parallel_param=parallel_param,
302 num_chunks=num_chunks,
303 chunk_size=chunk_size,
304 timeout=timeout,
305 )
307 return data
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/core/client.py:431, in BaseRester._submit_requests(self, url, criteria, use_document_model, parallel_param, num_chunks, chunk_size, timeout)
429 initial_params_list = [{"url": url, "verify": True, "params": copy(crit)} for crit in new_criteria]
--> 431 initial_data_tuples = self._multi_thread(use_document_model, initial_params_list)
433 for data, subtotal, crit_ind in initial_data_tuples:
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/core/client.py:636, in BaseRester._multi_thread(self, use_document_model, params_list, progress_bar, timeout)
634 for future in finished:
--> 636 data, subtotal = future.result()
638 if progress_bar is not None:
File /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/concurrent/futures/_base.py:438, in Future.result(self, timeout)
437 elif self._state == FINISHED:
--> 438 return self.__get_result()
440 self._condition.wait(timeout)
File /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/concurrent/futures/_base.py:390, in Future.__get_result(self)
389 try:
--> 390 raise self._exception
391 finally:
392 # Break a reference cycle with the exception in self._exception
File /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/concurrent/futures/thread.py:58, in _WorkItem.run(self)
57 try:
---> 58 result = self.fn(*self.args, **self.kwargs)
59 except BaseException as exc:
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/core/client.py:724, in BaseRester._submit_request_and_process(self, url, verify, params, use_document_model, timeout)
722 message = str(data)
--> 724 raise MPRestError(
725 f"REST query returned with error status code {response.status_code} "
726 f"on URL {response.url} with message:\n{message}"
727 )
MPRestError: REST query returned with error status code 404 on URL https://api.materialsproject.org/materials/mp-149/?_limit=1&_fields=structure with message:
Not Found
During handling of the above exception, another exception occurred:
Cell In[148], line 12
4 mpr = MPRester(api_key="F3MFJelQpJFdXiGdjtzH9lehJBngwRqz")
7 # mpr.materials.search(formula="CoSe2")
8 #
9 # for doc in mpr.materials.search(material_ids=["mp-149"]):
10 # print(doc)
---> 12 s = mpr.get_structure_by_material_id(material_id="mp-149")
13 print(s)
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/mprester.py:241, in MPRester.get_structure_by_material_id(self, material_id, final, conventional_unit_cell)
223 def get_structure_by_material_id(
224 self, material_id: str, final: bool = True, conventional_unit_cell: bool = False
225 ) -> Union[Structure, List[Structure]]:
226 """
227 Get a Structure corresponding to a material_id.
228
238 Structure object or list of Structure objects.
239 """
--> 241 structure_data = self.materials.get_structure_by_material_id(material_id=material_id, final=final)
243 if conventional_unit_cell and structure_data:
244 if final:
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/routes/materials.py:38, in MaterialsRester.get_structure_by_material_id(self, material_id, final)
25 """
26 Get a structure for a given Materials Project ID.
27
35 pymatgen structure objects.
36 """
37 if final:
---> 38 response = self.get_data_by_id(material_id, fields=["structure"])
39 return response.structure if response is not None else response # type: ignore
40 else:
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/core/client.py:857, in BaseRester.get_data_by_id(self, document_id, fields)
847 from mp_api.client.routes.materials import MaterialsRester
849 with MaterialsRester(
850 api_key=self.api_key,
851 endpoint=self.base_endpoint,
855 headers=self.headers,
856 ) as mpr:
--> 857 docs = mpr.search(task_ids=[document_id], fields=["material_id"])
859 if len(docs) > 0:
861 new_document_id = docs[0].get("material_id", None)
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/routes/materials.py:179, in MaterialsRester.search(self, material_ids, chemsys, crystal_system, density, deprecated, elements, exclude_elements, formula, num_elements, num_sites, spacegroup_number, spacegroup_symbol, task_ids, volume, sort_fields, num_chunks, chunk_size, all_fields, fields)
169 query_params.update(
170 {"_sort_fields": ",".join([s.strip() for s in sort_fields])}
171 )
173 query_params = {
174 entry: query_params[entry]
175 for entry in query_params
176 if query_params[entry] is not None
177 }
--> 179 return super()._search(
180 num_chunks=num_chunks,
181 chunk_size=chunk_size,
182 all_fields=all_fields,
183 fields=fields,
184 **query_params
185 )
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/core/client.py:911, in BaseRester._search(self, num_chunks, chunk_size, all_fields, fields, **kwargs)
888 """
889 A generic search method to retrieve documents matching specific parameters.
890
906 A list of documents.
907 """
908 # This method should be customized for each end point to give more user friendly,
909 # documented kwargs.
--> 911 return self._get_all_documents(
912 kwargs,
913 all_fields=all_fields,
914 fields=fields,
915 chunk_size=chunk_size,
916 num_chunks=num_chunks,
917 )
File ~/alex/lbl/projects/doping/denv/lib/python3.9/site-packages/mp_api/client/core/client.py:960, in BaseRester._get_all_documents(self, query_params, all_fields, fields, chunk_size, num_chunks)
946 list_entries = sorted(
947 (
948 (key, len(entry.split(",")))
955 reverse=True,
956 )
958 chosen_param = list_entries[0][0] if len(list_entries) > 0 else None
--> 960 results = self._query_resource(
961 query_params,
962 fields=fields,
963 parallel_param=chosen_param,
964 chunk_size=chunk_size,
965 num_chunks=num_chunks,
966 )
968 return results["data"]
294 if not url.endswith("/"):
295 url += "/"
298 url=url,
305 )
307 return data
309 except RequestException as ex:
427 remaining_docs_avail = {}
435 subtotals.append(subtotal)
632 finished, futures = wait(futures, return_when=FIRST_COMPLETED)
639 progress_bar.update(len(data["data"]))
436 raise CancelledError()
442 if self._state in [CANCELLED, CANCELLED_AND_NOTIFIED]:
388 if self._exception:
389 try:
391 finally:
393 self = None
55 return
57 try:
60 self.future.set_exception(exc)
721 except (KeyError, IndexError):
727 )
MPRestError: REST query returned with error status code 404 on URL https://api.materialsproject.org/materials/?deprecated=False&_fields=material_id&task_ids=mp-149&_limit=1000 with message:
Not Found
Really confusing and I thought I was doing something wrong, but updating client fixed it. Maybe some sort of warning based on the endpoint would be helpful (if it is not already taken care of for versions going forward)
