How can I design a spot heater in LAMMPS?
Let’s assume that I have a 100A100A20A block containing 22000 carbon atoms in my system. I want a heater of diameter 15A at the center of this rectangular block heated at a specific temperature (ex: 700K). I will introduce some other molecules close to the surface later to see their interaction with the heated and non heated surface region. Could anyone kindly suggest to me what should be the thermostat/ fix/ ensemble settings for the heater and the non-heater region in the simulation?
Any sort of help would be highly appreciated. Thank you.
Shahriar Mufid Rahman,
Research Assistant,
Dept of Mechanical Engineering,
Texas Tech University,
Lubbock, TX, 79415.
