request
Dear all
I have an ionic liquid with polar side chain length and I want to equilibrate my system. Since ILs are viscous and slow, equilibration of IL simulation box is not as easy as it is for normal solvents. When I use NPT condition to equilibrate my system, I see that density of my system (1.55gr/cm3) at 292 K is somewhat farther than experimental density (1.32gr/cm3) at 292 K. but when the temperature is high (500-600 K), density is very near to experimental density, although I cannot see this density at 292 K. maybe the problem is polarity of my system and I should cool down my system from 500-600 K to 292 K. Some guys suggested some ways to equilibrate my system. For example, in order to equilibriate IL systems, I should first run my simulations at higher temperature e.g. 500-600K with scaled charges (0, 10, 20, 50% of the full atomic charges) and then later I should slowly decrease the temperature to reach at 292K and increase the charges to 100%. I don’t know how I can scale my charges in lammps. I appreciate if somebody can give me a solution for my problem.
Cheers
Mehdi shakourian
Dear all
Check out the "set" command. For example:
set type 3 charge 0.5
http://lammps.sandia.gov/doc/set.html
Cheers
Cheers
Dear all
...and check out using fix adapt, which can do lots of nifty things.
