Requesting Help in Fixing an Error Related to Inserting Rigid Molecules By GCMC
Dear LAMMPS Users,
I am trying to insert the molecules by using fix GCMC while using fix rigid/small to make the inserted molecules behave as a rigid body but I am getting the following error:
ERROR: Fix gcmc and fix rigid/small not using same molecule template ID (…/fix_gcmc.cpp:549)
Below is my input script:
units real
atom_style full
read_data data.13_8
group bottom type 1 2
mass 1 95.94
mass 2 28.0855
group g_gcmc empty
pair_style rebomos
pair_coeff * * MoS.REBO.set5b M S
dump mydump all custom 1 dump_*.cfg id mol type x y z
dump_modify mydump element Mo S
molecule mos2 mos2.mol
region r_gcmc block EDGE EDGE EDGE EDGE 35 45
fix 1 bottom setforce 0 0 0
velocity bottom create 0.0 1
fix 2 all nve/limit 0.1
fix 3 g_gcmc gcmc 5 1 0 0 6700 1 0.1 1 mol mos2 region r_gcmc rigid 4
fix 4 g_gcmc rigid/small molecule
run 100
velocity g_gcmc set 0 0 -1
unfix 3
run 500
I am following the thread where almost same error is described here https://lammps.sandia.gov/threads/msg69983.html but it’s not exactly the same. Since there is a no thread available of the same error(or pardon me if I am unable to find it), can somebody please help to find out what’s wrong with my script.
I am using 22 Aug 2018 version of LAMMPS.
Thank you.
Dear LAMMPS Users,
…and this error message is pretty self-explanatory. rather than searching the mailing list for the off-chance of somebody reporting the same error without being able to figure it out, you should review the fix rigid/small documentation and figure out how to provide the same molecule template ID setting as used in fix gcmc. this should very straightforward to resolve.
Thanks Axel. It is working.
