Dear LAMMPS users,
I’m trying to create a LAMMPS script to post-procesate a trajectory using “rerun” command. I started from something simple and compute MSD for a trajectory in 2D. That was easy, but I have tried to compute velocity autocorrelation function (vacf) with the same scheme and always find vacf[*]=0
I have been reading “rerun” command page in the manual and I wonder if fix vacf is one these special cases when they write: “Every time a snapshot is read, the timestep for the simulation is reset, as if the reset_timestep command were used. This command has some restrictions as to what fixes can be defined…”.
Finally, to double check MSD, I have tried to compute directly the diffusion coefficient using the example in “compute vacf” page, but I get and error that I don’t know how to solve: ERROR on proc 0: Failed to allocate -8 bytes for array vector:vector (…/memory.cpp:63)
So, the main question: Isn’t it possible to compute vacf using “rerun” command? How exactly?
You can find the codes that I have used below in case you need it
Thank you very much
José
########################## LJ + NVT#####################################
dimension 2
units lj
atom_style atomic
lattice sq 0.5
region box block 0 100 0 100 -0.5 0.5
create_box 1 box
create_atoms 1 box
mass 1 1.0
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0
pair_modify shift yes
neighbor 0.3 bin
neigh_modify every 20 delay 0 check no
write_data Initial.lammpsdat
timestep 0.001
fix 1 all nvt temp 0.6 0.6 5.0
fix 2 all enforce2d
velocity all create 0.6 4928459 rot yes dist gaussian
dump id all custom 1000 traj.dat id type x y z vx vy vz
dump_modify id sort id
thermo 1000
run 1000000
##########################LJ+NVT#####################################
##########################MSD and VACF###############################
dimension 2
units lj
atom_style atomic
read_data Initial.lammpsdat
neighbor 0.3 bin
neigh_modify every 1 delay 0 check no
thermo 1
timestep 0.001
compute cvv all vacf
compute mss all msd
fix 1 all ave/time 1 1 1 c_cvv[] c_mss[] file test.dat
rerun traj.dat dump x y vx vy box yes label id id format native
#############################DIFFUSION###############################
dimension 2
units lj
atom_style atomic
pair_style lj/cut 3.0
neighbor 0.3 bin
thermo 1
timestep 0.001
compute 2 all vacf
fix 5 all vector 1 c_2[4]
variable diff equal dt*trap(f_5)
thermo_style custom step v_diff
