I am simulating a system consisting of 128 phosphonium ions consisting of one central charged phosphorous atom with four alkyle ligand and 128 negative borate ions. When I simulate this system at constant pressure using run_style respa with the recommended parameters in the manual
I get the correct density or at least a density that agrees with the one obtained from other programs but only if the timestep is very short - 0.4 fs. Therefore I would be very grateful if someone could tell whether ther is a better choice of paramaters for run_style respa.
Thank you im advance for the answer
before going that way. can you run this system well with run_style verlet?
