Dear LAMMPS devs,
I’m running a simulation with 2 slabs - one slab is modeled with OPLS while the other is modeled with Tersoff. Hence, I am using:
pair_style hybrid lj/cut/coul/long 10.0 12.0 tersoff
When I began the simulation, I read in a data file with all the pair coeffs in this form:
n lj/cut/coul/long eps sigma
After running the simulation, I wrote a restart file using write_restart and have since tried to load the restart file in a subsequent simulation but I get the error that the pair coeffs are missing. When I use the -r command line switch to make a data file, the pair coeffs are also missing. I’m using the Oct 9th, 2014 version of LAMMPS.
It’s not a critical issue since I have just redefined the pair coeffs in the input script but it would be nice if this could be fixed. Unless of course this is simply a user error, in which case I’d appreciate guidance. Thank you!
Alex
