Dear lammps users,
I want to deform oriented single crystal copper by using the following command:
lattice fcc 3.61 orient x 1 1 1 orient 1 -1 0 orient z 1 1 -2
After performing NPT, the triaxial deformation is applied using the following command:
fix 2 all deform 1000 x erate 0.005 y erate 0.005 z erate 0.005
But when I see pressure-time curve, then I found that the shape of the pressure-time curve is
changing with the increase in domain size. I have varied number of atoms from 10^5 to 1.28 x10^8 atoms.
Can anyone pls suggest me what I am doing wrong? I would like to appreciate your help in this regard.
Thanks in advance.
With best regards,
sunil
