retagging particles in verlet run
Dear LAMMPS users,
I’m adding/deleting particles in my fix and after doing it call the following code which I got from delete_atoms:
bigint nblocal = atom->nlocal;
MPI_Allreduce(&nblocal, &atom->natoms, 1, MPI_LMP_BIGINT, MPI_SUM, world);
if (atom->map_style) {
atom->nghost = 0;
atom->map_init();
atom->map_set();
Depending on the place this code is called I have different errors. if I put this code in post_force, I got the error when LAMMPS is checking that the simulation was valid it founds out some :
Bond atom missing in box size check (…/domain.cpp:642)
If I call it in post_integrate, surprisingly, I have a different error - wrong mapping when neighbor->build(); is called in verlet.cpp:
Bond atoms 1972 1727 missing on proc 1 at step 316 (…/neigh_bond.cpp:55)
This error happens only if I run the application on several cores, when a molecule is between processors.
Do you know possible ways to fix this problem? In the first case, I think it is because tags were changed but neighbor information hasn’t been renewed. Can I do it somehow in post_run or in other method which is called before domain checks?
Dear LAMMPS users,
I'm adding/deleting particles in my fix and after doing it call the
    atom->nghost = 0;
    atom->map_init();
    atom->map_set();
Bond atom missing in box size check (../domain.cpp:642)
Bond atoms 1972 1727 missing on proc 1 at step 316 (../neigh_bond.cpp:55)
is because tags were changed but neighbor information hasn't been renewed.
domain checks?
please have a look at fix gcmc. it runs at the pre-exchange phase of
an MD step and does similar things.
