Hello!
I am trying to use my API to retrieve EXAFS spectra for materials with Fe as the absorbing element, but the following code:
from emmet.core.xas import Edge, XASDoc, Type
with MPRester(My_API) as mpr:
fe_xas = mpr.materials.xas.search(edge=Edge.K,
spectrum_type=Type.EXAFS,
absorbing_element="Fe",
fields=["material_id","xas_id","spectrum","formula_pretty","edge","spectrum_type"])
results in the following error:
ValueError Traceback (most recent call last)
Cell In[3], line 2
1 with MPRester(My_API) as mpr:
----> 2 fe_xas = mpr.materials.xas.search(edge=Edge.K,
3 spectrum_type=Type.EXAFS,
4 absorbing_element="Fe",
5 fields=["material_id","xas_id","spectrum","formula_pretty","edge","spectrum_type"])
File d:\ANACONDA\envs\XANES\Lib\site-packages\mp_api\client\routes\materials\xas.py:101, in XASRester.search(self, edge, absorbing_element, formula, chemsys, elements, material_ids, spectrum_type, spectrum_ids, num_chunks, chunk_size, all_fields, fields)
93 query_params.update({"spectrum_ids": ",".join(spectrum_ids)})
95 query_params = {
96 entry: query_params[entry]
97 for entry in query_params
98 if query_params[entry] is not None
99 }
--> 101 return super()._search(
102 num_chunks=num_chunks,
103 chunk_size=chunk_size,
104 all_fields=all_fields,
105 fields=fields,
106 **query_params,
107 )
File d:\ANACONDA\envs\XANES\Lib\site-packages\mp_api\client\core\client.py:1185, in BaseRester._search(self, num_chunks, chunk_size, all_fields, fields, **kwargs)
1163 """A generic search method to retrieve documents matching specific parameters.
1164
1165 Arguments:
1180 A list of documents.
1181 """
1182 # This method should be customized for each end point to give more user friendly,
1183 # documented kwargs.
-> 1185 return self._get_all_documents(
1186 kwargs,
1187 all_fields=all_fields,
1188 fields=fields,
1189 chunk_size=chunk_size,
1190 num_chunks=num_chunks,
1191 )
File d:\ANACONDA\envs\XANES\Lib\site-packages\mp_api\client\core\client.py:1258, in BaseRester._get_all_documents(self, query_params, all_fields, fields, chunk_size, num_chunks)
1244 list_entries = sorted(
1245 (
1246 (key, len(entry.split(",")))
1253 reverse=True,
1254 )
1256 chosen_param = list_entries[0][0] if len(list_entries) > 0 else None
-> 1258 results = self._query_resource(
1259 query_params,
1260 fields=fields,
1261 parallel_param=chosen_param,
1262 chunk_size=chunk_size,
1263 num_chunks=num_chunks,
1264 )
1266 return results["data"]
File d:\ANACONDA\envs\XANES\Lib\site-packages\mp_api\client\core\client.py:569, in BaseRester._query_resource(self, criteria, fields, suburl, use_document_model, parallel_param, num_chunks, chunk_size, timeout)
567 data["meta"]["total_doc"] = len(data["data"])
568 else:
--> 569 data = self._submit_requests(
570 url=url,
571 criteria=criteria,
572 use_document_model=not query_s3 and use_document_model,
573 parallel_param=parallel_param,
574 num_chunks=num_chunks,
575 chunk_size=chunk_size,
576 timeout=timeout,
577 )
578 return data
580 except RequestException as ex:
File d:\ANACONDA\envs\XANES\Lib\site-packages\mp_api\client\core\client.py:874, in BaseRester._submit_requests(self, url, criteria, use_document_model, chunk_size, parallel_param, num_chunks, timeout)
871 remaining -= crit["_limit"]
873 # Submit requests and process data
--> 874 data_tuples = self._multi_thread(
875 self._submit_request_and_process, params_list, pbar
876 )
878 for data, _, _ in data_tuples:
879 total_data["data"].extend(data["data"])
File d:\ANACONDA\envs\XANES\Lib\site-packages\mp_api\client\core\client.py:938, in BaseRester._multi_thread(self, func, params_list, progress_bar)
935 finished, futures = wait(futures, return_when=FIRST_COMPLETED)
937 for future in finished:
--> 938 data, subtotal = future.result()
940 if progress_bar is not None:
941 if isinstance(data, dict):
File d:\ANACONDA\envs\XANES\Lib\concurrent\futures\_base.py:449, in Future.result(self, timeout)
447 raise CancelledError()
448 elif self._state == FINISHED:
--> 449 return self.__get_result()
451 self._condition.wait(timeout)
453 if self._state in [CANCELLED, CANCELLED_AND_NOTIFIED]:
File d:\ANACONDA\envs\XANES\Lib\concurrent\futures\_base.py:401, in Future.__get_result(self)
399 if self._exception:
400 try:
--> 401 raise self._exception
402 finally:
403 # Break a reference cycle with the exception in self._exception
404 self = None
File d:\ANACONDA\envs\XANES\Lib\concurrent\futures\thread.py:58, in _WorkItem.run(self)
55 return
57 try:
---> 58 result = self.fn(*self.args, **self.kwargs)
59 except BaseException as exc:
60 self.future.set_exception(exc)
File d:\ANACONDA\envs\XANES\Lib\site-packages\mp_api\client\core\client.py:1003, in BaseRester._submit_request_and_process(self, url, verify, params, use_document_model, timeout)
1001 if response.status_code == 200:
1002 if self.monty_decode:
-> 1003 data = json.loads(response.text, cls=MontyDecoder)
1004 else:
1005 data = json.loads(response.text)
File d:\ANACONDA\envs\XANES\Lib\json\__init__.py:359, in loads(s, cls, object_hook, parse_float, parse_int, parse_constant, object_pairs_hook, **kw)
357 if parse_constant is not None:
358 kw['parse_constant'] = parse_constant
--> 359 return cls(**kw).decode(s)
File d:\ANACONDA\envs\XANES\Lib\site-packages\monty\json.py:875, in MontyDecoder.decode(self, s)
873 else:
874 d = json.loads(s)
--> 875 return self.process_decoded(d)
File d:\ANACONDA\envs\XANES\Lib\site-packages\monty\json.py:853, in MontyDecoder.process_decoded(self, d)
845 elif (
846 (bson is not None)
847 and modname == "bson.objectid"
848 and classname == "ObjectId"
849 ):
850 return bson.objectid.ObjectId(d["oid"])
852 return {
--> 853 self.process_decoded(k): self.process_decoded(v) for k, v in d.items()
854 }
856 if isinstance(d, list):
857 return [self.process_decoded(x) for x in d]
File d:\ANACONDA\envs\XANES\Lib\site-packages\monty\json.py:857, in MontyDecoder.process_decoded(self, d)
852 return {
854 }
--> 857 return [self.process_decoded(x) for x in d]
859 return d
845 elif (
849 ):
852 return {
854 }
File d:\ANACONDA\envs\XANES\Lib\site-packages\monty\json.py:790, in MontyDecoder.process_decoded(self, d)
788 data = {k: v for k, v in d.items() if not k.startswith("@")}
789 if hasattr(cls_, "from_dict"):
--> 790 return cls_.from_dict(data)
791 if issubclass(cls_, Enum):
792 return cls_(d["value"])
File d:\ANACONDA\envs\XANES\Lib\site-packages\monty\json.py:249, in MSONable.from_dict(cls, d)
236 """
237
238 Args:
242 MSONable class.
243 """
244 decoded = {
245 k: MontyDecoder().process_decoded(v)
246 for k, v in d.items()
247 if not k.startswith("@")
248 }
--> 249 return cls(**decoded)
File d:\ANACONDA\envs\XANES\Lib\site-packages\pymatgen\analysis\xas\spectrum.py:77, in XAS.__init__(self, x, y, structure, absorbing_element, edge, spectrum_type, absorbing_index)
75 # check for empty spectra and negative intensities
76 if sum(1 for i in self.y if i <= 0) / len(self.y) > 0.05:
---> 77 raise ValueError("Double check the intensities. Most of them are non-positive.")
ValueError: Double check the intensities. Most of them are non-positive.
However, I don’t encounter any errors when retrieving EXAFS data for other elements, such as Co.
