I would like to retrieve workfunction that is available at Materials Project.
For example, look at: https://materialsproject.org/materials/mp-72/ ; here I would like to retrieve the ‘Surfaces’ table (Located above the Elasticity data) and place it in a data frame.
Can this be done using API?
Thanks.
Nitin
AFAIK there’s no way to fetch the data in a single query, but you can use a combination of the has
and the get_surface_data
method in the python api to get all of the data, something like:
from pymatgen import MPRester
import pandas as pd
import tqdm
with MPRester() as mpr:
data = mpr.query({"has": "surfaces"},
['material_id', 'pretty_formula'])
all_sdata = []
for datum in tqdm.tqdm(data):
agg_sdata = mpr.get_surface_data(datum['material_id'])
surfaces = agg_sdata['surfaces']
for surface in surfaces:
surface.update(datum)
all_sdata.extend(surfaces)
df = pd.DataFrame(all_sdata)
