I would like to retrieve workfunction that is available at Materials Project.
For example, look at: https://materialsproject.org/materials/mp-72/ ; here I would like to retrieve the ‘Surfaces’ table (Located above the Elasticity data) and place it in a data frame.
Can this be done using matminer’s MPDataRetrieval? If not, could you please suggest alternatives?
Also, if anyone is familiar, please suggest other databases from where I can retrieve calculated/experimental information about work functions, electron affinities, ionization potentials?
Thanks.
Nitin
Hi Nitin,
Unfortunately, MPDataRetrieval can only access properties that are available through the Materials API:
https://www.materialsproject.org/open
https://www.materialsproject.org/docs/api
Actually, I do not know of any tool that can get this data. I would suggest
i) contacting Materials Project help (click “forum” at bottom of page)
ii) checking out the paper, which might include the work functions as part of their data set submission:
R. Tran, Z. Xu, B. Radhakrishnan, D. Winston, W. Sun, K. A. Persson, S. P. Ong, Surface Energies of Elemental Crystals, Scientific Data, 2016, 3:160080 doi: 10.1038/sdata.2016.80.
You might try the Citrine search engine (https://citrination.com/users/sign_in)
Thanks.
Nitin
