Attached is the input. The error is: Reuse of compute ID, but I only use the compute ID once…
Anne
temp.galliumsim (357 Bytes)
Anne
compute ID once...
but this compute id is used internally by LAMMPS. it is explained in
the manual all over the place.
on top of that, your definition is meaningless, since you are exactly
recreating a compute that is already defined. you can just access the
compute id.
