Hello everyone,
I’m currently running LAMMPS 16Mar18 and using “fix rigid/small” with “fix pour molecule”. I am simulating granular flow in a quasi-two-dimensional hopper and when I use the following molecule template for the aforementioned fixes everything works fine:
Molecule file for dimers
2 atoms
Coords
1 -0.6 0.0 0.0
2 0.6 0.0 0.0
Types
1 2
2 2
Diameters
1 1.2
2 1.2
Masses
1 1.728
2 1.728
However, when I introduce a third particle with a coordinate of “0 0 0” (i.e. stuck between the two particles mentioned above), the rigid objects no longer rotate; the only translate as if the rotational degrees of freedom were
subtracted. I tried various configurations and noticed this only occurs when I have overlapping particles in my rigid body. I also looked through the fix rigid documentation but could not find anything mentioning this.
Any help understanding what is going on here is greatly appreciated.
Thank you for your time,
Justin
