Perhaps you can accomplish what you want using the "displace_atoms"
command, in conjunction with other commands. But in the long run, the
complexity of your system may eventually reach a point where you
should consider creating a LAMMPS data file. "Data" files give you
complete freedom to control the position and orientation of every atom
in your system (as well as add bond topology).
The basic "Data" file format is explained here:
https://lammps.sandia.gov/doc/2001/data_format.html
... however that documentation does not explain how to add
non-point-like particles (eg. ellipsoids). The complete documentation
(including a discussion of ellipsoidal particles) can be found in
these two links:
https://lammps.sandia.gov/doc/read_data.html
https://lammps.sandia.gov/doc/atom_style.html
----- moltemplate advertisement ----
...as it happens, there's an example of building a complicated system
of ellipsoids here
https://www.moltemplate.org/visual_examples.html#ellipsoids
additional files for this same example are located here:
https://github.com/jewettaij/moltemplate/tree/master/examples/coarse_grained/ellipsoids_CG_benzene
...however you have to install "moltemplate" to prepare the "data"
file which LAMMPS needs.
(Disclaimer: I wrote moltemplate. Thanks to Otello Roscioni, and
Matteo Ricci for the example.)
Note: The system shown there was intentionally made more complicated
than a simple crystal. (It has more in common with a cholesteric
phase than a smectic phase.)
If instead, you want a simple crystal with all of the ellipses pointed
in the same direction, then edit the "system.lt" file in that example
and change:
bulk = new BENZ
[5].move(7, 0, 0)
[5].move(0, 7, 0).rot(10,0,1,0)
[5].move(0, 0, 7)
to this:
bulk = new BENZ
[5].move(7, 0, 0)
[5].move(0, 7, 0)
[5].move(0, 0, 7)
You can apply a rotation to all of the individual "Benz" molecules
(particles) in the array using this syntax:
bulk[*][*][*].rot(45,0,1,0)
Feel free to change the names of these objects (ie "BENZ" and "bulk")
to something more appropriate to your system.
Note: This will give you a crystalline phase, not a Smectic phase.
Moltemplate does not have an easy way to introduce random
perturbations to the entries in an array. But you can many individual
commands to move and rotate each molecule in the array individually
(although this would be quite arduous). Hopefully, it shouldn't
matter. The force-field parameters you are using should hopefully
spontaneously allow the particles to relax into a Smectic phase when
they reach thermal equilibrium at the appropriate temperature, even if
the initial conformation was crystalline.
Note 2: You can edit the shape of the ellipsoids from disks to rods,
by editing (and perhaps renaming) the "benzene_cg.lt" file, and
modifying these parameters:
# atom-ID width1 width2 width3 qw qx qy qz
write("Data Ellipsoids"){
$atom:ben 6.3888 6.3888 3.1967 1.0 0.0 0.0 0.0
Hope this is helpful to someone who simulates ellipsoids.
Cheers
Andrew
