Hello All,
I have been trying to equilibrate a (10,10) CNT of length 50 A/ 100 A using modified Tersoff potential. After relaxation of the structure, when the structure is thermostatted to evolve under canonical ensemble (NVT), the CNT seems to gradually gain rigid rotation. In particular, if the atoms of the CNT are monitored, it shows rotational drift. Is it physical or an artifact of the potential or errors in running the simulation. My Lammps script goes like
clear
atom_style atomic
atom_modify map arrayCNT setup
read_data ${infile}
group sol type 1------------------- FORCE FIELDS----------------------------
pair_style hybrid tersoff lj/sf 3.0 lj/sf 3.0
pair_coeff * * tersoff C.tersoff C NULL # C-C
pair_coeff 2 2 lj/sf 1 0.0 0.0 # Ar-Ar
pair_coeff 1 2 lj/sf 2 0.0 0.0 # C-Ar#-------------------- NEIGHBOR UPDATING CRITERIA -------------
neighbor 3.0 bin
neigh_modify delay 5#-------------------- MINIMIZATION ---------------------------
fix fi1 sol box/relax z 0.0
minimize 1e-25 1e-25 5000 10000
thermo 1
thermo_style custom step v_torz v_comx v_comy v_comz
unfix fi1fix fi0 sol recenter {comxs} {comys} NULL units box
thermo 1
thermo_style custom step v_lxs v_lys v_lzs v_torz v_comx v_comy v_comz
run 5
unfix fi0reset_timestep 0
timestep ${t_stp1}#gaussian velocity distribution to each atom
velocity sol create {beg_temp} {velseed} mom yes rot yes dist gaussian
velocity sol zero angular#constant volume time integration
fix fi3 sol npt temp {beg_temp} {end_temp} 20.0 z 0.0 0.0 1000.0
fix fi4 sol recenter {comxs} {comys} NULL#Set thermo output
thermo ${thermo_freq1}
thermo_style custom step v_lxs v_lys v_lzs press pe ke temp v_torz v_omeg
fix p1 id1 print 1 “{vx1} {vy1}” file id400.cor screen no
fix p2 sol print 1 “{torx} {tory} {torz}" file CNT.tor screen no fix p3 sol print 1 "{omeg} {comx} {comy} ${comz}” file CNT.omeg screen norun {n_step1} write_restart restart.{outfile}
unfix fi3
unfix fi4Any suggestions will be much appreciated
De
-Subhadeep De
Graduate student
CMN Group
