Thanks Axel and Steve, and sorry for this delay reply. I have solved the my problem through reading the package command which is ignored at first.
I am using 4 GPUs (Tesla C1060), and the system number is about 20k.
While reading the package command for gpu, I can not understand the following statements:
"As an example, if you have two GPUs per node and 8 CPU cores per node, and would like to run on 4 nodes (32 cores) with dynamic balancing of force calculation across CPU and GPU cores, you could specify"
"package gpu force/neigh 0 1 -1"
My question is where the "-1" comes from (package gpu force/neigh 0 1 -1). From the syntax of package command, "-1" represents the fraction of particles assigned to the GPU. Can it be negative? If I have 8 nodes, with 4 GPUs and 16 CPU cores per node, what should this value be?
Best wishes,
Xiaohui
