run multiple lammps simulation in a consecutive way
Dear lammps-users,
I want to loop over my lammps input script file to run multiple simulations in a consecutive way, using the last simulation’s restart file as the next simulation’s initial input file. During one computing process, lammps will output the trajectory file-dump file and restart file. And then I will run my script to analyze the dump file to get the result I want, after that the dump file will be overlaped by the next new simulation.
for run in 1 2 3 4; # Run multiple simulations in a consecutive way
lammps simulation… # writes trajectory file and restart file
python_script analyze 0 $run &
python_script analyze 1 $run &
python_script analyze 2 $run &
python_script analyze 3 $run &
python_script analyze 4 $run &
done
Try this:
(1) write an input script that reads a restart file, performs a run,
and appends output to a dump file, and writes a new restart file
which includes the final timestep in the filename
(2) If your read_restart command includes the “*” char
in the filename, it will read the highest numbered restart
file that exists.
Thus you can run this script again and again to continue a simulation.
Note that this has nothing to do with Python. People do this for
batch queue systems, where they want their simulaion to run
multiple times in chunks to enable a very long simulation.
Dear lammps-users,
in a consecutive way, using the last simulation's restart file as the next
simulation's initial input file. During one computing process, lammps will
lammps simulation.... # writes trajectory file and restart file
done
Has anyone done that before? If yes, could you share your script with me? Or
any suggestions will be welcomed. Thanks very much.
this is most easily done with a "real" scripting language, i.e. not
the one inside of LAMMPS.
e.g. using a bourne shell script:
for run in `seq 1 4`
do \
    mpirun lmp_mpi -in in.script -log log.script.\{run\} \-var run {run}
    ./python_script analyze 0 \{run\}     \./python\_script analyze 1 {run}
    ./python_script analyze 2 \{run\}     \./python\_script analyze 3 {run}
    ./python_script analyze 4 ${run}
done
ps. you most likely do *not* want to background your analysis this way
or your next loop iteration will start before your analysis is
completed. either drop the '&' or add a 'wait' before the 'done' or
you'll have problems with your analysis and/or create a so-called
"fork-bomb".
