Running 2 fixes simultaneously
Can I run two fixes simultaneously?
My requirements is to move a set of atoms in a line while moving perpendicular to its traveling direction.
I really appreciate your comments.
Thank you.
Best Regards
Buddhika
sure. just read the documentation and
have a look at the examples. many use
multiple fix commands.
huh??
Dear axel,
Thanks a lot for your reply.
Can you specifically name one example?
If I explain bit more about my requirement, please assume that I have a box and I want to move it forward while moving back and forth to its perpendicular direction of motion.
I think I can use following fixes.
  • "fix move " to indicate the forward motion.
    -“fix wiggle” can be used to represent the “perpendicular motion”
Currently I’m struggling . to combine these two motion at once.
I appreciate your suggestions.
Best Regards
Buddhika
Dear axel,
the examples folder is full of them.
please make an effort. i don't have
the time to spoonfeed people.
- "fix move " to indicate the forward motion.
-"fix wiggle" can be used to represent the "perpendicular motion"
Currently I'm struggling . to combine these two motion at once.
struggling in which way?
please post a (as simple as possible) example.
i cannot read minds (of people or computers), and
it is very difficult to argue about things hypothetically.
the situation is simple. if you follow the manual,
it should work. since it doesn't, you must be
doing something wrong. but if we don't see it,
nobody can tell what.
