I have never used Lammps and the KIM api before, and I wanted to get a very simple lattice parameter versus temperature curve for Aluminum using the Mendelev potential
(https://openkim.org/dev-kim-item/TE_957040092249_000-and-MO_106969701023_002-tr)
It seems like this has already been done, as the above link shows the result for the coefficient of thermal expansion, which is just the slope of the curve that I wish to plot. I wished to get some guidance about what’s the best way to tweak the thermal expansion test to get the plot I want.
I use a Mac (OS X 10.9.5) and downloaded the latest lammps and kim-api tarballs from the corresponding websites, but I am struggling to install the KIM_API, which I thought was necessary before i went along installing Lammps.
I tried ./configure in the kim-api-v1.8.2 folder, but that somehow didn’t find any compilers
checking for the GNU Compiler Suite (gcc, g++, gfortran)… no
checking for the INTEL Compiler Suite (icc, icpc, ifort)… no
unable to identify a complete compiler suite. Exiting.
Then I tried just using ‘make’ by renaming the example makefile, but it gave me an error saying:
make: *** No rule to make target `/Users/Ishan/kim-api-v1.8.2/build_system/Makefile.Generic’. Stop.
Can someone please guide me through this process?(If possible, both the installation of KIM and Lammps?) Thank you very much in advance!
Sincerely,
Ishan Tembhekar
