Running errors of LAMMPS GPU bench test
Dear Alex,
Yes, I can run the parallel simulation successfully without gpu package. The previous problem was solved after I re-configured the /etc/ld.so.conf by adding the /usr/local/cuda/lib64.
However, when I tried to test a simple input file (attached), below error occurred:
wuchao@…4131…:~/software/LAMMPS_GPU_Install/Drivers/lammps-24Apr13/bench/GPU> mpirun -np 8 ./lmp_g++ -sf gpu -c off -v g 1 -echo screen < in.test
LAMMPS (24 Apr 2013)
package gpu force/neigh 0 0 1
3d Lennard-Jones melt
newton off
atom_style atomic
lattice fcc 3.615
Lattice spacing in x,y,z = 3.615 3.615 3.615
region box block 0 10 0 10 0 10
create_box 1 box
Created orthogonal box = (0 0 0) to (36.15 36.15 36.15)
2 by 2 by 2 MPI processor grid
pair_style eam/gpu
pair_coeff 1 1 Cu_u3.eam
create_atoms 1 box
Created 4000 atoms
velocity all create 1.44 87287 loop geom
neighbor 2.0 bin
neigh_modify delay 0 every 20 check no
fix 1 all nve
run 100
in.test (394 Bytes)
Dear Alex,
why not use LD_LIBRARY_PATH?
occurred:
[email protected]...:~/software/LAMMPS_GPU_Install/Drivers/lammps-24Apr13/bench/GPU>
it works for me.
Yes, I have also already exported the LD_LIBRARY_PATH in the /etc/profile, as export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib64, but it didn’t work until I specified it in the /etc/ld.so.conf.
I am glad to know that the simple input file works for you, but still confused why it doesn’t work for me. Is there any clue for my problem? Thanks in advance!
Junjie
as export
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib64, but it didn't work
just editing /etc/profile doesn't automatically change your current session.
confused why it doesn't work for me. Is there any clue for my problem?
no clue. it must be something in your machine setup or your hardware.
Hi axel,
I re-configured the machine again, using MPICH2-1.2.1p1 and FFTW2.1.5. It seems that there is some progress as the error of Segmentation fault disappeared. But the simulation still doesn’t work with below new error message:
wuchao@…4131…:~/software/LAMMPS_GPU_Install/Drivers/lammps-24Apr13/bench/GPU> mpirun -np 8 ./lmp_g++ -sf gpu -c off -v g 1 < in.test
Created 4000 atoms
