I’m testing new the feature “fix atom/swap”. It seems to work very well on a single core. When I run it on 4 cores it returned error:
ERROR: Delta_mu not allowed when not using semi-grand in fix atom/swap command (…/fix_atom_swap.cpp:216)
Then I initialized the variable:
ndeltamutypes=0;
in the function void FixAtomSwap::options(int narg, char **arg)
and now had another error:
Setting up run …
Memory usage per processor = 4.14107 Mbytes
Step Temp PotEng Lx Ly Lz Volume
10000 302.79298 -5.2033227 45.222532 45.143987 37.613579 76789.077
MPI Application rank 0 killed before MPI_Finalize() with signal 11
Now I have no idea how to fix this. I’m using the latest git version.
Regards,
Konstantin
I'm testing new the feature "fix atom/swap". It seems to work very well on a
command (../fix_atom_swap.cpp:216)
ndeltamutypes=0;
Setting up run ...
76789.077
Now I have no idea how to fix this. I'm using the latest git version.
...which has been updated since you posted your e-mail. please update
and try again.
Hi Axel,
Yes, I’ve seen and updated it today. The bug is still there.
ERROR: Delta_mu not allowed when not using semi-grand in fix atom/swap command (…/fix_atom_swap.cpp:215)
Also, option ke=yes does’t conserve momentum. A structure starts to move with a constant speed…
I understood that fix has been added just two weeks ago, so many updates will appear.
Cheers,
Konstantin
Hi Axel,
Yes, I've seen and updated it today. The bug is still there.
command (../fix_atom_swap.cpp:215)
Also, option ke=yes does't conserve momentum. A structure starts to move
with a constant speed...
will appear.
and they are likely to appear faster, if you'd provide paul with a
suitable test case.
Here is my input. Also this bug appears on a single core if you comment command thermo_style in my script.
Co3Pt_swap.zip (346 KB)
Thanks for the test case. I’ll take a look and let you know what I find.
Paul
I just checked in a fix for this issue.
Paul
On the non-conservation of momentum, note that you can use fix atom/swap’s “ke=no” option to conserve momentum (but not kinetic energy). See: http://lammps.sandia.gov/doc/fix_atom_swap.html . Also note that LAMMPS has a fix for re-zeroing momentum: http://lammps.sandia.gov/doc/fix_momentum.html . And LAMMPS also has various thermostat fixes for maintaining T and hence kinetic energy.
The other issues you previously mentioned have been addressed and the patch is now available.
Paul
