Hi all!
I want to study the permeation of gases through 2d-membranes via molecular dynamics simulations. In my case I simulate helium atoms through nanoporous graphene membranes and I need to compute the flux of He atoms crossing from one side of the graphene surface to the other side. I use a standard Lennard-Jones potential for the C-He and the He-He interactions, and no interaction between carbons.
My problem is that when I run in parallel I obtain a very different result for the flux of He atoms, in comparison with the serial running (differences of 25%). I have tried with different timesteps but the problem stays.
If anyone could help me or can show me some documentation to learn using LAMMPS in parallel I would be very grateful.
Alfonso.
Hi all!
problem stays.
why should the size of the time step have an impact on the result of
these kind of studies?
it is *extremely* unlikely, that your difference is due to using
LAMMPS in parallel vs. serial.
there has to be some other issue in your approach that causes such a
large systematic difference.
