Hi all,
Today I’ve received a new computer to run my LAMMPS simulations on. This beauty has a Intel Xeon E5-2609 v2 quadcore CPU, but the cores are split over two independent chips (2 cores each). When I try to configure LAMMPS to utilise all 4 cores (command “processors 2 2 1”) I get an error: “ERROR: Specified processors != physical processors”. I assume this error is raised because a single chip only has 2 cores, but so far I couldn’t figure out how to include the other 2 cores as well. Can anybody tell me what I’m supposed to do to get this working?
(I’m using the 2 Apr 2013 version of LAMMPS)
Regards,
Martijn van den Ende
Hi all,
Today I've received a new computer to run my LAMMPS simulations on. This
utilise all 4 cores (command "processors 2 2 1") I get an error: "ERROR:
Specified processors != physical processors". I assume this error is raised
Not likely. Have you checked your input script if there is a
"processor" command defined?
Ray
Hi all,
no. this is not what the processors command does. please read the
documentation more carefully. the processors command only determines
how to *map* the processors to the x-, y-, and z- dimension. the total
number of processors is specified via the mpirun or mpiexec command.
of course, for that you first have to have LAMMPS compiled with MPI
support (or install a suitable pre-compiled version).
because a single chip only has 2 cores, but so far I couldn't figure out how
no.
to include the other 2 cores as well. Can anybody tell me what I'm supposed
have a look at the documentation and (perhaps) at an MPI tutorial.
Thanks for your reply, I found the problem. When I still had 2 cores available and I wanted to run LAMMPS, I invoked the command "mpirun -np 2 lmp_openmpi < scriptfile.in". But since I didn't want to type that entire line each time, I made an alias for that. On my new computer I adjusted the alias in my .bashrc file to use 4 cores, but I forgot to source it before running the code again... (awkward)
It works now on all cores, thanks for your help.
Martijn
not awkward at all.
however, it shows the problem with using aliases (you forget the real command).
that is why i prefer to put a shell script called ./run.sh into my
working directories when i run interactive production calculations.
this way i also save effort (even more than with an alias) *and* have
a record of how i ran the code.
